Need Shock help of Trail Blazer 250
Old Sep 26, 2002 | 10:30 AM
endmumma's Avatar
I need to change the rear shock spring on my wifes Trail Blazer. I have a spring compressor. But once I compress the spring, do I remove the bottom part where you adjust it with the spanner wrench to get the spring off? Thanks
Old Sep 26, 2002 | 03:21 PM
Mike Chero's Avatar
No,
Remove the top washer. It should be slotted for removal.
Old Sep 26, 2002 | 03:43 PM
endmumma's Avatar
When you say the top washer, you mean the very top of the shock? I have not removed the shock from the quad yet. In just a quick glance there appears to be plenty of room to remove the bottom shock bolt campared to the top shock bolt.
Old Sep 27, 2002 | 09:15 AM
Mike Chero's Avatar
There is a washer at the top of the spring. This washer keeps the spring on the shock at the top. There should be a slot on the washer that will allow you to slide the washer through the shock absorber rod once the spring is compressed.
Polarisman1123
Aug 13, 2015 08:13 AM
Mssarabug
Aug 10, 2015 12:56 PM
07Redrider400
Jul 25, 2015 05:31 PM
Gnuters
Jul 19, 2015 10:03 AM
cSchwartz
Jul 9, 2015 02:40 PM
