Mojave wont start when hot.
Old Mar 27, 2000 | 10:59 PM
mojo's Avatar
I just put my motor back together and now when its hot and you shut it off it wont restart. The only way to get it to start is to drag it and pop the clutch. The pilot screw is 1 3/4 turns out and it idles great when i do get it started. The motor is 1mm over,K&N filter and main jetted at 134 and has a DG pipe. I can smell gas when i'm kicking it over and the plug shows signs of running rich. It still has the stock constant velocity carb. What could be wrong? The float level is right in spec. Im running out of ideas I hope someone can help. Thanks.
Old Mar 27, 2000 | 11:04 PM
brandon's Avatar
I had a bike once that did this. It turned out tot be a faulty breaker in the electrical system. When it would get hot, it would not start. I had to use the backup pull starter. I'm not real sure how I found the problem, but after I did, it started right up no matter how hot ti was.
Old Mar 27, 2000 | 11:12 PM
mojo's Avatar
Even after it cools down it wont restart.It takes a couple days to be able to cold start it again. Thanks for the reply.
Old Mar 28, 2000 | 12:21 AM
richy26's Avatar
CHECK TO SEE IF YOUR TIMING IS OFF AND ALSO CHECK YOUR VALVES. THEY MAY NEED TO BE ADJUSTED.
Old Mar 28, 2000 | 01:28 PM
BrianWSNC's Avatar
OK..this sounds funny, but when we used to rebuild engines, alot of the times the carbs had to be rebuilt too.. we called it "Carburator shock"
I think it has to with if you accidently turn it upside down and the trash gets inside the internal ports and passages..
what it sounds like it's doing it flooding the engine after you have shut it down.. what you can't see is the needle and seat maybe leaking causing a no running flood condition. When you go to restart it.. it's hard to fire.. you smell gas ,it spits and sputters till you blow out the excess fuel and then it runs fine..
the reason it has to sit a few days before a sucessful cold start is it takes time for the fuel to bleed past the cylinder into the crankcase.. which reminds me.. check and change your oil too... if the rebuild fixes this problem.
Old Mar 29, 2000 | 09:58 PM
WhiteWarrior's Avatar
Try turning the gas off when you turn it off, It sounds like its flooding out.
Old Mar 31, 2000 | 12:28 AM
Mxracer98's Avatar
It's probaly because the mojave has such a high compression. (11:1) Mine has the probaly to but eventually starts when its hot
Old Apr 1, 2000 | 08:38 PM
Mojave99's Avatar
i have a 99 and 00 Mojave and havent had any problems with it restarting hot... check your valves... it sounds like they are getting hot and expanding beyond their tolerances.... i have had problems with the float too.... so make sure when you do stop even for a few minutes shut the gas off and see if that helps...or when you go to restart it hot... when you kick it over try giving it gas at the same time... wide open at the same time you kick it... but dont hold it open as soon as it sounds like it's starting let off the gas!! when you flood an engine your not getting enough air to mix with the gas... so you have to open it up to start it... try it and see if that helps
Old Apr 2, 2000 | 10:13 PM
mojo's Avatar
Thanks everyone for your help.It turned out to be the head gasket. The brand new head gasket. Be forewarned Cometic gaskets are ****!!!! It leaked around the whole gasket. I put the old one back in with a little copper gasket spray and I'm good as new. It starts rite up first kick, cold or hot. Thanks again for your help.
Specwar
Jun 27, 2015 08:59 PM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
Reconrider
Aug 30, 1999 02:17 PM
dunc_n
Aug 26, 1999 09:32 PM
