Squeaky Shocks.....
I have the same problem, believe it or not, it is not the shock it is the rubber mounts, I have good luck with a small bit of oil but it is slightly messy and only lasts a few rides or so. I was told not to use WD-40 because it would harm the rubber, but if anybody could contradict that eveidence it would be much easier and cleaner with a good shot of WD-40
I had the same problem last year, I prayed my rubber shock mounts with a Graphite spray and have ridden all year so far without even a little squeek.
WLscrambler is right on the money, I have researched this topic a lot, and found that loosening the top shock mount bolt will cure your problem. I did mine, and I have never had a squeak. Try it. it will work.
