Steering Stem Slop
Old Oct 9, 2002 | 11:24 AM
54warrior's Avatar
Default Steering Stem Slop
Has anyone had problems with up and down slop in the steering stem? My stem has probably an inch of up and down movement. I thought the nut on the bottom may be loose, but that wasn't the case. Any suggestions?
Old Oct 9, 2002 | 11:31 AM
lt250r91's Avatar
Check the bearing at the bottom of the stem. It rides in a plate ***'y right below the tie rod ends. mine had a similar problem and it was a combination of the bolts that hold this bearing in being loose and the plates were bent (spread apart) allowing the bearing to move up and down. If this is the case remove the stem nut and the mounting bolts for the bearing assembly and pull the stem up enough so you can remove the bearing and plates. Either replace the plates or smash them back together so the bearing can ride it them without moving up and down. The reassemble everything and put some locktite on the bearing bolts so they don't work loose again.
Old Oct 10, 2002 | 10:02 AM
54warrior's Avatar
What all is involved in removing the stem? does the airbox type thing have to be removed? How long do you think it will take to do this?
Old Oct 10, 2002 | 01:12 PM
Cdale1's Avatar
the air box dosnt have to be removed
juat undo the nut and push the stem up high enough to get the plate out
Cdale1
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
