banshee magineto
Old Oct 9, 2002 | 09:04 PM
JohnJAbood's Avatar
Default banshee magineto
when installin a set of led lights on the banshee, since there is no battery what do i connect the power wire to for a charge? any help would be helpful. also when in stallin aftermarket lights on the banshee what should i hook them up to?
Old Oct 10, 2002 | 01:05 PM
WyoDuner's Avatar
Need more details on what you are trying to do. I can tell you that the stock stator can barely run the stock headlights and tail-light. You can't run anymore than that without upgrading your stator. Ricky Stator is the most popular source for aftermarket stators. http://www.rickystator.com/
Old Oct 10, 2002 | 11:51 PM
JohnJAbood's Avatar
lets say that i have a high outpute sator, and i buy some lights for the handle bars. where should i connect the wires for the handle bar lights to. also, where did u get dot approved atv tires, casue i wanna street legalize my banshee. please tell me everything u did, pictures would be great, thanx. i have already been to the DMV and they said its ok in ct
Old Oct 11, 2002 | 12:01 AM
JohnJAbood's Avatar
when u went to the dmv did u say u want to registure ur atv or did u call it somethin else. all the help u can give needed. thanx
Old Oct 11, 2002 | 11:01 AM
WyoDuner's Avatar
John, you WILL need a high output stator to run additional lights... Some people have implemented battery systems ontheir banshees too, BTW. A Battery can keep the lights bright even when at idle but of course they take their power from the stator and the stock stator can barely run the lights as it is.
If you get the high output stator, you would connect the new lights in parallel with the stock lights... Be careful though as the extra load may be too much for the stock light switch and it may burn up - you may need to to a higher rated swith for the extra lights or ad a seperate switch for the handlebar lights.
I am street legal in Wyoming - it is super easy here but most states are EXTREMELY difficult to be street legal... I recommend you do a search onthe subject "street legal" , you will find a lot of posts.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
