98 Scrambler 4x4 snapping
Old Oct 20, 2002 | 09:16 PM
scramblazer400's Avatar
Default 98 Scrambler 4x4 snapping
When in 4x4 and on accel there is a loud snap or pop noise from the left side and the handlebars jerk to the left.
It seems to be doing this all the time.
I remember there being a time or 2 when i was in 4x4 and it pulled hard left like that was the
only wheel pulling then it would release
Any suggestions
Old Oct 20, 2002 | 11:05 PM
pudljumpr's Avatar
First, check each of your front hubs and make sure there is oil, but since it only does it in 4x4, take the front hub off, you must remove the brake caliper first, and there is a flat black washer with 3 points that sits next to the magnet...make sure that these aren't bent or that anything else isn't out of alignment.
2002 Scrambler X 400 4x4
K&N air filter
hpd mods coming as soon as warranty wears off!
Old Oct 20, 2002 | 11:42 PM
swampdonkeykiller's Avatar
It sounds like your one hub is momentarily unlocking and then locking up again. Could be a bad wire de-energizing your hub lock or your hub is wore out causing the rollers to skip internally. Your spring that holds the rollers all together may also be broken allowing the rollers get out of place a little. Take your hub ont left side apart and check out your hardware. If everything inside is in good shape, check out the wiring to it.
Old Oct 21, 2002 | 10:56 PM
Well upon further review I found an exploded cv joint bearing cage on the
right side
Thanks for the suggestions
Old Oct 23, 2002 | 04:34 AM
Yes that would make sense. Can't believe I overlooked that one![img]i/expressions/face-icon-small-blush.gif[/img]
exmotocrosser
Sep 13, 2019 06:12 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
