Anyone know the specs on Polaris Green Spring????
Anyone know the Specs on Polaris #7041168 Green Spring such as:
Stall Preload (lbs.).......???
Stall Increase RPM.......???
Full Shift (lbs.).............???
On the Hot Seat Diagram its just above Polaris White. The Polaris Green appears to be exactly in the same range as Hot Seat's Green which is reccomended for 4 strokes.
Is this the same Green Sping that eveyone gets from rittercycle???
Anyone help out with this........Please
Go to HPD's website an click on clutching. www.hpd-inc.com They give the engagement pressure and full shift numbers for most of the oem springs and their own as well. Hope this helps,Bubba
Don't know about the Polaris green, but Aaen has a green primary....60lbs stall preload.....400rpm stall increase.....200 fullshift lbs. It's a nice spring. It really woke up my Trailboss.
If you have a manual it has a chart listing all of polaris springs everything you want to know.The green has a 50 lbs stall and 140 lbs full shift if that helps you any.
