02 H0 SHIMMY
Old Oct 26, 2002 | 12:53 PM
NANNIE's Avatar
Default 02 H0 SHIMMY
MY 02 500HO HAS A SHIMMY IN THE FRONT END.IT IS MORE NOTICEABLE AT LOW SPEEDS. IF YOU LET GO OF THE HANDLE BARS IT BECOMES A VERY VIOLENT SHIMMY. MY MECH CALLED POLARIS AND THEY ARE GOING TO CHANGE THE FRONT TIRES TO SEE IF THIS CORRECTS THE PROBLEM.ANY OF YOU RIDERS HAD THIS PROBLEM ? IF SO PLEASE LET ME KNOW WHAT YOU DID. THANKS
Old Oct 26, 2002 | 01:25 PM
pest44's Avatar
Mine does it, but I think it is due to rolling it over when I first got it. I broke one of the front cv joints. The joint was replaced and I put new wheels on it and it is still there, but not as bad b/c I think the wheel was warped. I think my front hub is bent. You can tell a slight wobble when rotating the hub w/o the wheel on it. I suppose you haven't wrecked it at all. If not, it could be coming from some slop in your tie rod ends which is very common on the sportsmans, even the 01's and 02's.
Old Oct 26, 2002 | 04:34 PM
Stittsville's Avatar
Hope that new tires will fix your trouble.. Still think it is alignment related.. New tread on front wont hurt anyway.....
Old Oct 27, 2002 | 02:03 PM
filthyhabit's Avatar
heres my two cents dont let go of the bars
beagleboy
Oct 16, 2010 07:09 AM
rockout
Feb 8, 2009 07:27 PM
ZR1BANDIT
Apr 16, 2005 10:19 PM
scrambler420
Aug 23, 2003 07:14 PM
