Hit a stump on my 400ex...
Old Nov 2, 2002 | 04:51 PM
love250x's Avatar
Default Hit a stump on my 400ex...
I clipped a stump very hard today on my 400ex and the bars shot back and hit me in the knee. When I got off to check my rims they werent bent. When i move the tire sideways there a little bit of play in the top ball joint. Also if I lift up hard on the top a-arm the a-arm will move up slightly, and the other ball joint doesnt do this. I didnt check before to see if i already had that problem so i dont know if the stump did it or not. The bolt on the botton side of the ball joint is tight. Is this a problem that needs to be fixxed immediately, if i ride anymore will the ball joint break and my wheel fall off? Thanks.
Old Nov 2, 2002 | 09:03 PM
RaceWarrior350's Avatar
If hittin that stump didnt do it i wouldnt think so, all u can do is ride it a little and see if it gets worse, if it doesnt give it a few small jumps check it if its ok then do a nice one and see what happens, dunno what else to tell ya-
K&E Racing
"Move Ex's get your junky a*ses out my way"
"Go Big Or Go The F*ck Home"
"Hold it down, If it blows let it"
88 Warrior-
To Many Mods To List
99 Blaster-
Gold Series fatty pipe
Power Core 2 Silencer
Old Nov 2, 2002 | 10:48 PM
SportTrax250ex's Avatar
i would just keep an eye on it for now. if its a little loose now it will only get worse over time. buy a replacement ball joint now and save it back for when it does get very bad.
Old Nov 3, 2002 | 02:12 AM
drip's Avatar
I would take the ball joint loose from the spindle and see how much free movement is in the ball joint. If there is I would recommend replacing it asap. If you have stock a-arms you will have to buy the complete a-arm which is about $70 for the upper a-arm and around $47 for the lower a-arm. At least you didn't do what I did. I hit a tree, bent the right side a-arms and ripped them out of the frame. I had to have my frame welded and I had to buy new a-arms. I bought extended a-arms which I like a lot, but right now I am replacing the delron(plastic) bushings with some brass ones my friend and I are making.
ReconBayou
Oct 31, 2022 05:37 PM
donintennessee
Jan 8, 2021 12:40 PM
Bob E.
Oct 1, 2019 09:08 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Hw00d
Sep 10, 2015 08:53 AM
