ds90 light?
Old Nov 2, 2002 | 09:13 PM
TrEvIn's Avatar
Default ds90 light?
Has any one put a light on the Ds90??? We bought two lights one for the Ds90 and for the LT80! I was just wondering if any one has put one on or any thing
Old Nov 7, 2002 | 02:27 AM
scooter8's Avatar
Default ds90 light?
I put a light on my daughters ds90 all you have to do is mount the light and wire it.I grounded the light under a mount bolt for the light on run a wire to the connector by the left rear frame.I don't remember which of the three wires but if you use the right wire the light will work with the key switch.It's been on it for a year with no problems.Hope this helps.
Old Nov 7, 2002 | 04:17 PM
BajaMark's Avatar
Default ds90 light?
My buddy has a 2002 DS 90 for his kid. We were talking about a light and found a three wire harnass tie wrapped to the frame just behind where a light would be if there was one. Does anybody know if this is a good harnass for a light?
Old Nov 7, 2002 | 05:44 PM
TrEvIn's Avatar
Default ds90 light?
Well we did was got a little metal brace made and were going to put on were the handle bars are for the ds90 and same for the lt80....Did you guys hook up the light to the key the second or third turn of the key would have the light on? We are going to hook ours up with a little switch.......
Old Nov 7, 2002 | 09:19 PM
scooter8's Avatar
Default ds90 light?
There are a couple connectors on the ds90 (2 stroke) the only one I found to work was the one by the left rear frame.The ligth works in the third key position.I mounted my daughters light behind the opening in the front bumper.I used a clear foglight for a truck ($20 from walmart and have a spare) ran a strap across and under the lower bumper bolts.It looks like it was made for in there.And shines plenty good so she can ride at nigth.Hope this info helps.
Old Nov 8, 2002 | 10:35 PM
TrEvIn's Avatar
Default ds90 light?
Alright! well were going to be putting the lights on soon!
Old Nov 9, 2002 | 07:42 PM
TrEvIn's Avatar
Default ds90 light?
We hooked up the lights today! It took us a little wile on the ds90 but we got it working and at night we tried it out but it was shineing high in the trees so we fixed it...To operate the light there is a little red switch wich glows up when the lights on......We had a little trouble with the Lt but we got it after a wile! Thanks for all the help!
95wolv
Sep 27, 2024 12:00 PM
wendal
Sep 7, 2019 06:46 AM
hueby
Nov 6, 2015 11:34 AM
panicmanic
Sep 28, 2015 12:59 PM
Alex G.
Sep 16, 2015 12:13 PM
