Where to put DS plates?
Old Nov 3, 2002 | 11:21 AM
sheman's Avatar
Default Where to put DS plates?
Anyone have any suggestions on where to put the license plate on the Baja? Didn't worry about it at first but their getting pretty fussy here about having your plate on your bike and I really can't find a place for the thing.Tried a few spots but it really looks out of place everywhere I've tried.Help!
Old Nov 3, 2002 | 11:28 AM
MadBaja819's Avatar
If it was me I would mount in somewhere on the front bumper, because regardless of location it is going to look out of place. That sucks that they are actualy enforcing the law around you.
Old Nov 3, 2002 | 11:50 AM
sheman's Avatar
Oh they're enforcing the law pretty good here lately .There's been a few "acting up" lately so everyone else has to pay.They've even headed a big Suburban down through the bike trails here just to check the bikes and even have seized and towed at least one, so I guess its time to stick the plate on and avoid the trouble.
Old Nov 3, 2002 | 12:01 PM
MadBaja819's Avatar
Wow that really sucks, but I know what ya mean when you say we all have to be punished for a few acting up irresponsible people.
Old Nov 3, 2002 | 01:37 PM
crashnburn's Avatar
sheman, I put mine under the rear grab bar. I could send you a picture if I had your e-mail.
Old Nov 3, 2002 | 08:22 PM
lilnotts's Avatar
i mounted mine behind the rear light on the plastic piece that comes down, it will look like this wen finshed,
Old Nov 3, 2002 | 08:50 PM
dsguru's Avatar
I used flat bar drilled a couple holes in it and bolted it to the tail light bolts.So it mounts just below the tail light .The bolt holes on the tail light are the same width as the holes in the lic plate.Ontario plate that is!
Old Nov 3, 2002 | 10:13 PM
DuneMe's Avatar
I did mine same as Illnotts. Went to TAP Plastics and had them cut me a piece of plastic then drilled a couple holes in it and mounted with zip ties. Would have rather used Aluminum but, couldn't find any that cheap. The plastic was less than a buck and it is tucked up away pretty good so, probably won't have to worry about breaking.
Old Nov 4, 2002 | 04:32 PM
sheman's Avatar
Great idea to put it there . Doesn't look out of place at all . Didn't really want it stuck out in the open to much and that looks like the ideal spot.
Old Nov 5, 2002 | 12:17 AM
Air's Avatar
Air
Are there not two holes behind the light for it already???
