Tapping auxilary power (Quest 650)
Hi, I have just got hold the Quest 650 4x4 about a week ago. Plannig to strip the vehicle and tap auxiliary power for the crank shaft. Will be integrating a pulley and belt system on the extended crankshaft and mounting will be on the plugged mounting holes on the casing.
Has anyone out there done this before? Will the casing be able to withstand the pounding and will the engine lose its balance? This will be the major mod. Will be including a roll cage, extending the rear prop shafts and etc.
Need some advice on this. Cheers
BUG
BUG
MeadowlarkFarm
Nov 27, 2019 08:40 PM
