Ice Racing set-up
Old Nov 13, 2002 | 08:14 AM
dawzie's Avatar
Default Ice Racing set-up
I'm new to ice racing. Need to know what tires, sway-bar, gearing, mapping, what ever needed. Have a '02 Cannibal with Walsh +3 arms and Walsh +1 swing arm.
Old Nov 13, 2002 | 09:05 AM
cannondale27's Avatar
Cheng Chin rear tires c826 some run the small some run the wide I prefer the small ones for four stroke.Dunlop fronts I cant remember what style.I like the Rath swaybars any will work gearing depends on the size track.Same with the mapping 1/3 mi oval or less moto map works good.Bigger oval the speed map.I like the studs which are cone shaped in middle you can sharpen those I think they are gold diggers.When you put the studs in inflate the tire to 20psi then when you let the air out it will hold the studs in better.I run studs that are long enough to go through the tire if they dont go through they will fall out.And after going through all the work of putting thousands of studs in your tires dont use them on anything but ice some guys will even put carpeting around them to get to the ice.What district do you race in maybe I will see you on the ice?
Old Nov 15, 2002 | 05:28 PM
dawzie's Avatar
Does anyone else have any input ?? I also would like info on places that hold ice racing here in New England.
Old Feb 26, 2009 | 07:11 PM
mx360snow's Avatar
I know and have been to a place in sturbridge mass. Its pretty big and its every weekend. Its lots of fun and I think I might try it out next year.
Johnny Mac
Aug 15, 2019 03:13 PM
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
