? on 1994 300 fourtrax
Old Nov 18, 2002 | 05:34 PM
robnhouston's Avatar
Default ? on 1994 300 fourtrax
My brother in law just picked this atv up. It has 3 lights on the dash. Far left is the red reverse, center is a green neutral and there is another RED one on the far right. When you turn the key on a relay in the back clicks, the light comes on then automatically goes out.
What is this third light. We'll pick up a manual someday.
Thanks,
Rob
Old Nov 18, 2002 | 05:43 PM
DirtDevil86's Avatar
it might be the "oil temp" light. thats what the third light is on my '87 250 fourtrax. hope this helps.
Old Nov 19, 2002 | 12:59 AM
KNOWSALOT's Avatar
The Facility
DirtDevil is right.
There is an oil temprature sensor on the engine that activates the light when the oil gets to hot.
It comes on at intial startup just to let you know that the system is working properly.
If it comes on when while you are riding, stop the engine a few minutes for a cooldown. This happens alot on quads used for work or where slow riding for long periods of time occur.
If the light ever comes on right after you start it up and doesn't go off, you most likely have a bad sensor.........or a break in the wiring.
Old Nov 19, 2002 | 08:11 PM
2000IAWarrior's Avatar
the one on the right is reverse middle nuteral left oil temp
Old Nov 19, 2002 | 08:12 PM
wiat a min i messed up ill have to look i think the red ones are swithced
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
