sparks reed cage for a 250r
Old Nov 21, 2002 | 09:44 AM
airtimehocutt's Avatar
Default sparks reed cage for a 250r
anybody currently using a sparks reed cage on their 250r? i bought one and after installing it there is a 3/8 inch gap between the rear of the carb an the stock airbox boot. what seems to be the way to correct this problem. sparks said to cut the front airbox mounting post off and move them forward. i did this but now the air boot is hitting the shock. thanks for the help
Old Nov 21, 2002 | 07:21 PM
TEAMSPARKS's Avatar
Install a reed spacer.That will take up the space and make the power hit smoother!
Old Nov 25, 2002 | 06:32 PM
i asked scott at sparks about the reed spacer. he said the spacer was just for the 330cc kit and bigger. have you tried the spacer on a smaller motor?
Old Nov 25, 2002 | 06:45 PM
briansgi's Avatar
Someone makes an aluminum "tube" which you can install and lengthen that section. Can't remember if it's Eddie Sanders or who you can get that from. I had the same problem, I ended up removing the 2 rubber pieces on the subframe the airbox rested on, unscrewed the rear screw on the airbox and I was able to move mine forward enough to get that sucker clamped in place.
Old Nov 30, 2002 | 11:30 AM
well, i spoke with scott again. he said you had to use a spacer on the 1986 model cylinders. well, that is what my friends has, so i ordered him a spacer. well see what that does when it comes in.
Polaris-400
Aug 19, 2015 02:20 AM
Bergmann
Aug 13, 2015 03:51 PM
CRamshaw777
Jul 18, 2015 05:46 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
