Axle Nut Question (for those with "the book")
Old Nov 25, 2002 | 01:56 PM
kehale's Avatar
Default Axle Nut Question (for those with "the book")
From the rear (DS650), there is an adjustment nut (LARGE) with a locking clamp on it.
WHat is the side to side play of the axle supposed to be (if any) ?
Mine is about 1/4". I noticed it after I heard some clicking while leaning side to side.
Isn't this thing supposed to be torqued relatively tight? (e.g. no play)
Not sure.
Anyone have the answer?
I've ordered the book, but it's not in til Wednesday! [img]i/expressions/face-icon-small-sad.gif[/img]
Thanks for any help you can offer.
-T
Old Nov 25, 2002 | 02:10 PM
kehale's Avatar
the quad has about 5 hours on it. I'm sure it came loose during my last outing (with I rolled it).
I'll take it apart to check for wear and dirt, just to be sure.
Thanks,
T
Old Nov 25, 2002 | 04:24 PM
kehale's Avatar
Can't even make it budge!
Oh well, back to the dealer.
_T
Old Nov 25, 2002 | 08:41 PM
StevieD's Avatar
i had the same problem with my 400EX. i, being a dumbbutt, turned the locking nut to teh right, instead of left, loosening it...so i had taken it out riding, and i heard a sqweek coming from the axle housing.(at first i thought it was the clutch, but it wasnt ,,,thank god) well anyway, my bearings and seals were completely screwed, so i ordered a new set. in fact, i just got them today, put it back together, and rode it around the lawn for a bit.
on to your question, there isnt supposed to be any play in the axle...im still not sure how there could be 1\4" of side-to-side play in it, cuz, like mine, the brake rotor would rub up against the brake pads...that may have been the clicking noise you heard..
Old Nov 25, 2002 | 08:48 PM
JSsDS's Avatar
Mine loosened up in the first 5 hours too. I got lucky no sand in the bearings so I didn't have to leave it at the dealer for repair.
Actually it kept lossening up until ultimately I had to grind a little out of the slit in the nut(where the bolt goes through and closes it like a clam) so it would tighten down better against the threads. The ends of the slit touched before it tightened.
I havn't had a problem since.
cornermike
Sep 10, 2015 08:30 AM
John Reed
Sep 9, 2015 03:46 AM
bmark0610
Sep 7, 2015 09:42 PM
MooseHenden
Sep 6, 2015 04:24 PM
snowolson
Aug 31, 2015 03:51 PM
