need help jetting mojave
Old Apr 3, 2000 | 08:40 PM
nikbrew's Avatar
just put a twist trottel and dg steel pipe on my 2000 movaje. i moved the main jet up from a 132 to a 135. It idels super high now, like 2000 rpm it soulds like. the idel adjuster is moved all the way down, and trottel isent stuck open. do i just need to put the stock jet back in?
Old Apr 3, 2000 | 08:48 PM
Jeffksf's Avatar
Seeing how you installed a twist throttle I assume you either installed a new cable or modified the existing one. I would check the cable and its adjustments and make sure its allowing the carb to shut all the way. Since you said the idle adjustment is bottomed out that tells me to look at the cable. The jet size sounds right.
Jeff
93' mojave: Supertrapp, ported head, 11.5:1 piston
and much more.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
