Modifying 350X with 400EX parts???
Old Dec 2, 2002 | 04:46 PM
biggerisbetter's Avatar
Default Modifying 350X with 400EX parts???
OKay I have a brother that has upgraded his 400EX to a 440 along with hot cams etc. I have another brother that has a CHERRY 85' 350X. My question is, can you make the stock 400ex piston work in a 350X motor? and the cam also??
Is it possible?
Thanks
Biggerisbetter.
Old Dec 4, 2002 | 01:11 AM
KNOWSALOT's Avatar
The Facility
Neither will work.
The wristpin on the 350X is larger and the piston has a different deck height from the 350X.
The cam wont work simply because both engines are so different. The 400EX is a RFVC type.
Powroll offers lots of parts for the 350X to make it scream.
If it's any consolation to you....the 350X can be built to make more power than a 400EX can be built for. It all depends on the size of your pocket book.
Old Dec 5, 2002 | 11:20 AM
Thanks Knowsalot! (thats all I needed)
I knew if you saw this thread you would reply, and with the good info.[img]i/expressions/face-icon-small-smile.gif[/img]
Thanks agian.
Biggerisbetter.
Old Dec 22, 2002 | 09:25 PM
Trx440's Avatar
The head and jug from the FT 500 Ascot can be mated to the 350x bottom end. I am not sure how big or how much power it had but I saw one years ago @ Silver Lake, Mi and it was unbeatable.
Old Dec 24, 2002 | 12:26 AM
Trx440,
Thanks for the reply, FT ascott 500??? was that a honda motor? and was it a single cylinder? I thought the old Ascotts were twins.
DO you have any more info on this One-off machine??? sounds cool!
Biggerisbetter.
Old Jan 1, 2003 | 01:07 PM
AlkyBurninX's Avatar
Knowsalot, will the RFVC head or head/clyinder from an XR350 work on the 350x bottom end? What about the 250x/XR250? What have you heard about the ascott combo? I too thought it was a twin.
Old Jan 2, 2003 | 11:03 AM
Trx440's Avatar
There was a FT 500 single the first year, then a V-twin the following year. They were both called Ascot. -RT
Old Jan 5, 2003 | 02:13 AM
mad200xer's Avatar
I do know that and 87 XR 500 cylinder on up will bolt to a 350x and een line up in the mounts perfect, but it dosen't have the oil lines so you hca to block them off from the case...
Old Feb 11, 2003 | 03:04 PM
Joel85350X's Avatar
Hey mad200xer, I don't find any information on a 1987 XR 500. I don't think they made it then. All I find is a 400 and 600.
Anyone know which it is for sure? I would like to try this top end as a project.
Old Feb 18, 2003 | 03:21 PM
HondaATC's Avatar
XR/XL/FT 500 series topends DO NOT fit onto 350X bottom ends. I have pictures to prove it. Even if they did, the topen is about a inch and a half or so taller, which would make it nearly impossible to fit into a 350X frame without hacking on it.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
Asaran
Oct 8, 2015 11:14 AM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
metal249
Jul 28, 2015 09:35 AM
95wolv
Jul 21, 2015 12:25 PM
