master link
Old Dec 3, 2002 | 03:27 PM
flattrack650's Avatar
Default master link
is anyone still afraid to use a master link on the ds, the reason i ask is because i woould like to be able to change gears without taking my swingarm off. )yea i know picky picky). Or maybe there is an easier way. But any way i bought the 35 and 43 tooth sprockets and would like to have a custom chain with 2 master links in it to run the 3 sprockets it would be a 530 but it will have 2 530 master links in it. Lastly what chain length do you use for your 43 and 35 tooth sprockets. thanks for the help
Old Dec 3, 2002 | 07:25 PM
AZDUNNER's Avatar
Default master link
You should have no problem with two Master Links. I have been using a Master Link for two years with no negative effects.
Why would you take your swing arm off to change gearing? You must mean the right rear hub. You don't need to mess w/ the S/A at all.
Your chain lenght depends on what front sprocket your running with the rear.
I have run 17/37 and not needed to adjust the chain length.
Old Dec 3, 2002 | 07:55 PM
Default master link
yes the right hub to change the sprocket but the s/a to change the chain because with the 35 and the 43 tooth sprocket are too drastic of a size chain to adjust the stock chain to fit.
Old Dec 3, 2002 | 10:38 PM
FasterThenYou's Avatar
Default master link
When i got a master fro my quad the 530 would not fit...I had to use a 525, but maybe yours is different
Old Dec 4, 2002 | 11:32 PM
SANDMAN430's Avatar
Default master link
i went 112 on my 15-43 but i think you can get by on 110, i wanted to have enough to go bigger front
salixair
Nov 3, 2015 08:25 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
bigred20653
Oct 2, 2015 10:05 AM
1ArmBandit
Sep 8, 2015 08:59 PM
JakeXBL
Sep 5, 2015 01:08 PM
