Moose Plows E-Z Lift vs. Warn Electric Lift Kit
For those who have the Warn Electric Lift Kit, How reliable are they? Do they hold up? How about the E-Z Lift by Moose, Does it work well. Purchasing 50" Moose County plow and want to hear opinions on what works best with that specific plow. Does the Warn lift raise the blade high enough? I don't need the winch so I really don't want to go that route. I just don't think that I would use the winch outside of the winter season so I don't want to go to that route. By the way the plow is going on a 2002 Rubicon, if that influences your advice. Thanks in advance for the info.
GO HONDA, I purchased a kodiak 450 a couple weeks ago and they had a promotion going with a $69.00 warn winch at the time. I also was interested in the moose plow kit. The 50" plow with install kit, push tubes and, fairlead cost me an additional $330.00 installed. Ive only used it 2x but, it seems like a real nice system that works well with the warn 2500lb.winch. The moose plow and kit are heavy duty and seemed to be better quality then others systems i had seen. The warn winch was rated better than the moose winch. Wish i could give you more info.
The warn electric lift kit isn't great. You need something that allows the winch to more directly lift the blade up. Go to www.montanajacks.com and you'll find exactly what you need.
Sw00p
Sep 24, 2015 02:50 PM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
