I Keep on blowing fuses on my 400ex!!! HELP ME
Yeah, I got a 400 ex and for the last couple of days I've blown 10 fuses in 2 days, I have no accesorys hooked up to the battery that weren't hookt up fromt eh beginning, I have no idea whats wrong.
If you know anything Please share! I couse use whatever help you got, Anything would do
DON'T put in a bigger fuse unless you want your bike to catch fire!!!!
There is definantly a problem there somewhere, most likely a short possibly causeed by a chafed wire. This is most likely the case if you haven't added any accesssories. Find the source of the problem then replace the fuse.
Put in a bigger fuse. At least that is what my friend did for his system in his car.
Bad advice!!!!
Look for chaffing on any and all wires,,,possibly contacting the frame or some othe metal componant. Around the steering stem,,,is a good spot to start looking.
As a rule, spray wd40 after every wash all over exposed wiring to help with moisture and chaffing.
Have you ever had water in your headlights? That is what caused my Wolverine to keep blowing fuses. The light terminal had corroded and caused a short. Put a fuse in and start jiggling a few wires at a time to se what may be causing your problem. Hope this helps
Check that you are in an appropriate sub forum(Honda, General, etc.) for your question. There will be a "New Topic" button at the top left. Same place the "Post Reply" button is if you are in a thread already.
