I Keep on blowing fuses on my 400ex!!! HELP ME
Old Dec 12, 2002 | 06:47 PM
RossDepanfilis's Avatar
Default I Keep on blowing fuses on my 400ex!!! HELP ME
Yeah, I got a 400 ex and for the last couple of days I've blown 10 fuses in 2 days, I have no accesorys hooked up to the battery that weren't hookt up fromt eh beginning, I have no idea whats wrong.
If you know anything Please share! I couse use whatever help you got, Anything would do
Old Dec 12, 2002 | 06:51 PM
300exRiderJay's Avatar
Put in a bigger fuse. At least that is what my friend did for his system in his car.
Old Dec 12, 2002 | 06:52 PM
RideRed420's Avatar
something is prabably shorting out...........
If you can,follow the wire that keeps blowing the fuse,
till you find something.......
thats about all you can do.......
Old Dec 12, 2002 | 09:37 PM
RacinJason's Avatar
Sounds like you have a simple wiring problem(bad ground or hot wire making its way to ground)chase that sucker back and see where it goes...Is the battery moving around?
Old Dec 13, 2002 | 10:27 AM
action450s's Avatar
DON'T put in a bigger fuse unless you want your bike to catch fire!!!!
There is definantly a problem there somewhere, most likely a short possibly causeed by a chafed wire. This is most likely the case if you haven't added any accesssories. Find the source of the problem then replace the fuse.
Old Dec 13, 2002 | 12:32 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
This is the worst thing you can do!!!
Bad advice!!!!
Look for chaffing on any and all wires,,,possibly contacting the frame or some othe metal componant. Around the steering stem,,,is a good spot to start looking.
As a rule, spray wd40 after every wash all over exposed wiring to help with moisture and chaffing.
Old Dec 13, 2002 | 01:35 PM
jcsact's Avatar
Have you ever had water in your headlights? That is what caused my Wolverine to keep blowing fuses. The light terminal had corroded and caused a short. Put a fuse in and start jiggling a few wires at a time to se what may be causing your problem. Hope this helps
Old Dec 13, 2002 | 11:31 PM
drag295RR's Avatar
first of all look at the fuse diagram on the cover and tell me what fuse keeps popping.
Old Aug 27, 2013 | 03:14 PM
Crawford714's Avatar
How do I post a question on this website, I'm not very technically inclined...
Old Aug 27, 2013 | 04:39 PM
Scooter86's Avatar
Knows Old ATV Questions!
Check that you are in an appropriate sub forum(Honda, General, etc.) for your question. There will be a "New Topic" button at the top left. Same place the "Post Reply" button is if you are in a thread already.
