Air box question???
Old Dec 14, 2002 | 06:47 PM
BabyMoose's Avatar
Default Air box question???
I was our riding today and noticed that I had oil mixed with gas in my air box. Just wondering what would cause this, and how big of trouble am I in. It seemed to be running fine.
Thanks in advanced!!!!
Old Dec 14, 2002 | 09:53 PM
jetjock16's Avatar
means gas and oil are gettin past your rings, time for a rebuild.
jetjock16.
Old Dec 14, 2002 | 09:59 PM
Sandaholic's Avatar
Do you stand the quad up when u tow it? or Flip it over? I have seen gas wash the oil off an air filter and leave the filter oil in the air box
Old Dec 14, 2002 | 11:20 PM
DuneMe's Avatar
If you are set-up stock, the oil breather line comes in one of the snorkels. Oil could have got there from this. Are you sure about the gas?
Doubt you need a ring job.
Old Dec 14, 2002 | 11:47 PM
BabyMoose's Avatar
Yeah it was gas that I smelt. I ripped it all apart today, and the oil came in from the left hose, the one that has the oil breather going to, the other one was completely clean. My dealership thinks that maybe of some water got in somehow, that it would build enough pressure to push oil out. I also did a quick oil change and that looked good still.
Thanks for the help so far!!!
Old Dec 15, 2002 | 03:34 PM
JSsDS's Avatar
There has been complaints of oil blow-by since day one. It doesn't happen on very many but it is not unheard of.
Blow-by is usually caused by compression that gets past the piston rings when combustion takes place in the cylinder. In the case of the Ds, many with this problem have built their engines with high compression pistons and bigger bore which is a complete replacement of the cylinder and piston, and still had the problem. This indicates that the blow-by is not from the rings but being generated elsewhere, yet undiscovered.
As for the gas, blow-by oil has a slight amount of gas in it so you can smell it.
I suggest you don't tear it down!! Just ride the crap out of it and clean the box every now and then.
If you are still unsattisfied, you can do a compression test (disable the compression release first) to measure the integrity of the rings.
Old Dec 15, 2002 | 05:11 PM
SANDMAN430's Avatar
i think the oil in the breather line is some what normal, just the machines vary slightly some more than others. one of mine has more than the other. the one that has more oil out the vent is faster so, ring blow bye isn't what i think it is.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
