TRX90 headlight
Hello Everyone,
I recently bought my kids a TRX-90 for Christmas and was wondering if there was a way to add a headlight to the trx-90? Beings that there is no battery, I wasn’t sure if you could get it to work like the old 3-wheelers. I also notice that National Motor make an identical quad or (ripe-off of the TRX-90) it has a battery and electric start. That being said, maybe someone knows how I could get my hands on the wiring diagram for the Nation Motor quad or if the TRX-90’s that is shipped to Canada, already has a Headlight? (Never Know…till u ask) any suggestions would be greatly appreciated. thanks in Advance,
Rydogg
Rydogg
The TRX 90 has no wiring for lights ,you will need to get the stator rewound for a light coil output to run a head and tail light. Ricky Stator makes a kit, and I'm sure several others offer one too. The wiring diagram for the other quad won't help you,they are totally different motor wise, and is a piece of junk compared to a Honda. Hope this helps you out.
Thanks a lot 95Wolv,
I found it here www.rickystator.com
Just as you Suggested, but not sure if I want to pay THAT for headlights.
Also, I talked to them at Ricky stator and you need a special pulley to remove the stator from the flywheel then you replace with the new one. I also asked if you could run a brake/taillight with this system. He thought that with an 1157 type bulb it would be to close for comfort, but with a led type bulb you should be fine.
Thanks again for the quick response.
Merry Christmas, Ho Ho Ho and Don't be one! [img]i/expressions/face-icon-small-happy.gif[/img]
Rydogg
Rydogg
Just bought the Ricky Stator lighting coil for my son's TRX90...it works great for a small quad...it was easy to follow the directions, and I had the old one out and the new one in and lights installed within 75 minutes.
Cost was $120 including the ac adaptor and shipping
We took a simple route to make the TRX more visable in the woods. Added a single front 30w light and a rear LED red light, stuck a battery in the storage compartment under the seat and hooked it all up through a fuse and a switch. Of course, the only way to charge it is to hook a charger up to it during down times, but it powers the lights for 4 to 5 hours.
Jaybee
Jaybee
I would look up Ricky Stator, as I think if anyone would have it he would. Good luck
Originally posted by: Rydogg
Hello Everyone,
Rydogg
Hello Everyone,
Rydogg
rickystator.com has a full light kit for a trx 90. It comes with a new 90 watt rs stator to run two 35watt halogen lights they mount to a bracket wich mounts to the front bumper it has the wiring harness and ac voltage regulator. The bad thing is there on when ever the engine is running. I saw it a couple months back for about $100
