I almost forgot what it's like!
Old Dec 23, 2002 | 11:49 PM
WickedDS's Avatar
Default I almost forgot what it's like!
As some of you have noticed, I'm a new member of the forums. I'm an American, currently working in South Korea. Ordinarily, I spend my nights doing a bit of work but mostly supervising and surfing the web. I've been reading the posts, but never logged in to respond. I guess I just figured the rest of the world was asleep, like the country is here. Now that I've started posting, it's almost like having a conversation with other ATV enthusiasts, and that is something that is hard to come by over here.
Anyway, it's good to "talk" to some of you. Others I could definatly live without.[img]i/expressions/face-icon-small-wink.gif[/img]
The bad part is, when I'm stoping in to work in the middle of the day, your all fast asleep.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Dec 24, 2002 | 12:17 AM
biggerisbetter's Avatar
Well I'm not sure if anyones actually said welcome ,but WELCOME[img]i/expressions/face-icon-small-smile.gif[/img]
Look forwad to hearing some more of your opinions, and comments on the performace of our beloved DS's.
Biggerisbetter.
Old Dec 24, 2002 | 12:27 AM
sand45's Avatar
welcome .....WickedDS
Old Dec 24, 2002 | 01:04 AM
Majorecho's Avatar
that's gotta really bite to have your bike in FL. while your overseas.
Care to share what you've done to your DS?
Old Dec 24, 2002 | 01:28 AM
WickedDS's Avatar
It's about 797CC's, and most all of the top end {along with the crank}is one-off parts. The piston is actually from an entirely different aplication, and is what the rest of the motor is built around. The exhaust is custom bent, but flows into a Big Gun canister.
I've got three swing arms to run on it, +12", +9", and +6". The +12" is aluminum and would never hold up to anything but completely flat sand, dirt, or asphalt. I keep RAD titanium axles in the +9" and +12". A Durablue in the +6". I've never gotten around to getting a wheely bar made. I think it's more fun without it anyway.
I use 22" Holeshots in the dirt. I've actually taken it out on a friends MX track a few times. Hoosier 22" oval track tires at the drag strip. 25"-12 paddle Taller Haulers for sand.
It's not near as pretty as that Jeffrivercity guys DS is{At least judging by his pictures} but it isn't exactly ugly. It's got a candy blue frame and springs, with black plastic and A-arms. A shop in Florida did my seat in blue and black to match.
I really don't feel good about making claims on it's performance. I don't have any way to back up my numbers untill I get back, or untill I can get it to Glamis for your little get together. I will say that I've been reading the forum for a while and I haven't read about anything that has me concerned. I'll also say that the first time I got it on the dyno, it said 53 HP, so I know exactly what that Jeff guy feels like. I've gotten it on different dyno's a few times since then, and gotten much better results, but none of them completely acurate.
If I can get it to Glamis, I'll send some of the charts with it. If not, I'll dig them out next time I roll through the states.
I'm not trying to keep any secrets. I have nothing to gain or lose by telling everyone what I've done. I'm sure a couple of you could, but most could not afford to duplicate what I've done. I've just seen to many people post performance that wasn't that impressive, and be called a liar when they didn't come to someone elses track to prove it.
Old Dec 24, 2002 | 01:33 AM
Majorecho's Avatar
what fuels do you run in it?
Old Dec 24, 2002 | 01:56 AM
BLACKDS's Avatar
That Jeff guy wishes he could get 53 hp!![img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 24, 2002 | 02:02 AM
WickedDS's Avatar
That is why I'm guessing I would do OK against what I have read about.
Right now, the most I've tried is a 33% nitro blend. I've been told that the motor should handle up to 60% and still spin the RPM I use, but if I went higher, I would need to drop my red line. Personaly, I didn't run it up to the shift light when I was running the 33% mix, and really haven't had a huge desire to run any more fuel.
Usually, I use a 20% mix and have no concerns about it. I'm not much of an expert on tuning with fuel or methanol, so I don't experiment much on my own. I've noticed that if I stay with the set up I have, and 20%, it runs well regardless of altitude or temp.
Old Dec 24, 2002 | 02:13 AM
jeffnrivercity's Avatar
Holly sheep $hit!!
My turn to ask questions...
What..............
Bore & stroke?
Carburation?
Cams?
Compression ratio?
Ignition system?
And why a +12 axle[img]i/expressions/face-icon-small-shocked.gif[/img]
thats all................
Jeff
Old Dec 24, 2002 | 02:14 AM
WickedDS's Avatar
I'm sort of guessing that he has a bit more than that and the dyno was goofed. The way it was when I got my 53. If that's all he has, I'm really sort of surprized that you guys are impressed with his bike. I really hope his 4?HP was just a goof, wasn't it?
