bad hubs?
Old Dec 27, 2002 | 01:17 AM
djmac379's Avatar
Default bad hubs?
My son's 87 250x has a lot play at the rear hubs. Are the hubs bad or the axle or are there bearings that can be replaced?
Dan
Old Dec 27, 2002 | 12:11 PM
Buckeye400EX's Avatar
Default bad hubs?
DJMAC, there are no bearings in there, I'd be willing to bet your hubs need replaced. The hubs slide on the axle splines. After years of abuse and rust they loosen up. Take the cotter pin out and remove the large center hub nut and slide them off. You can inspect your axle shape at that time. WD40 it to clean out the splines and see if the axle is damaged. If it's ok, just get some new hubs, and you'll be good to go. I had a '91 250X and my bro in law still has a 1987. Scarlet and gray!! What's a guy from Michigan doing with a Buckeye quad? HA! Just kiddin ya.
Old Dec 27, 2002 | 07:51 PM
Elrancho's Avatar
Default bad hubs?
If the axle hub splines are trashed might as well do some spot welds to keep the wheels from wiggling untill you break the axle.
Old Dec 28, 2002 | 12:01 AM
djmac379's Avatar
Default bad hubs?
thanks for the advice. i am looking for a new axle cause the spline is bad at the sprocket anyway. when i replace the axle i will check out the hubs too. as far as the buckeye colors......... out of repect to michigan we moved away from the buckeye grey and scarlet to black and red! thanks again.
blueandy88
Sep 7, 2020 03:11 PM
jdunne01
Oct 4, 2015 10:29 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
snowolson
Aug 31, 2015 03:51 PM
blueandy88
Aug 30, 2015 08:26 PM
