200X Compression ratio to fuel
Old Jan 4, 2003 | 03:14 PM
mad200xer's Avatar
Default 200X Compression ratio to fuel
I am building my 200x and I am going to put a Powroll high compression piston in it. I don't know if I should go up to 12:1 or just to 10.5:1.... If i go up to 12:1 can I still run on pump gas? Stock ratio is 9.6:1 any help is greatly appriciated
Old Jan 4, 2003 | 06:34 PM
AlaskaYFM's Avatar
You would definitely have to run race gas at that compression with a 200X. Also, the reliability of your trike would go way down. I would stick with the 10.5:1 piston and also throw in a mid-range web cam. Besides those mods (combined with pipe and filter) you probably don't really want to do any extensive engine mods on the little ATC, because when you try to extract alot of power from that engine, bad things happen... [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 4, 2003 | 06:36 PM
mad200xer's Avatar
Well I am going with a powroll mid range cam, going to get my crank welded, and bigger vavle ports with powroll valves, I have never been to the web cam web site, are there cams hardwell or billet? Thanks for the input.
Old Jan 4, 2003 | 07:17 PM
woody660r's Avatar
got lots of 200x parts 84 85 year what you need???
Old Jan 4, 2003 | 10:58 PM
mad200xer's Avatar
E-mail me.
slowgsxr97
Mar 18, 2022 03:40 AM
Cummins Driver
Sep 11, 2019 01:22 PM
Austins
1) Engine problems..
Aug 9, 2015 02:28 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
ghost civic
Jul 19, 2015 10:13 AM
