Needle problem ?
Old Jan 7, 2003 | 01:33 AM
cOoLdevil's Avatar
Default Needle problem ?
hi all and can any one tell me what is the diffrance between the Needle position if its in 1# or 2# or 3# or 4# or 5# and where is the big diffrance in the atv when you change the Needle position .
my setting now is 175 main and Needle 4# 3 turns in air screw with lid on and k&n filter and after market complet system .
if thear is a better settings just tell me guys . thanks all
Old Jan 7, 2003 | 02:16 AM
JMAC650's Avatar
Check out Buttfungus's website. Search under "ds jetting/mods data". There is alot of helpfull info on his site.
Old Jan 7, 2003 | 09:05 PM
RotaxRulz's Avatar
cOoLdevil...the needle affects carburetion from about 1/4 to 3/4 throttle, and overlaps the pilot circuit and the main circuit, the lower the clip on the needle the richer,also the taper of the needle affects ratio, thicker taper=lean, thinner=richer,one of the way's to check the different circuits is to run the motor in the specific range you want to check, idle, mid,and wide open throttle, then pull the clutch and stop the motor, do not coast or idle the motor as it will change the color of the spark plug, pull the plug and check its color, light brown is good, black powder carbon=rich, white flaky ash=lean, set the main jet first as it has the most overlap, change one jet size at a time,then recheck, after the WOT looks good,then run at mid throttle, shut down the same, check the plug and adjust needle as required,typically if the motor idles smooth and does not hesitate the idle settings are ok....this is kind of a condensed version that I found at "http://204.71.0.3/motoprof/moto/mcycle/carb101/carb101.html"...many thanks go out to fine people who provide this important info.
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 20, 2015 12:36 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
