centrifugal decompressor ???
Old Jan 12, 2003 | 05:07 PM
FastYellow650's Avatar
Default centrifugal decompressor ???
what in the world does it do, and why is it there
Old Jan 12, 2003 | 05:59 PM
lilnotts's Avatar
i don't know, but i think they'll work just as good as ur TVI Clutch Sprinds [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 12, 2003 | 06:09 PM
i think your thinking of something else, what im talking about is at the end of the exhaust cam, i was wondering if its like a varible cam setup and if so how does it work, i dont understand the reasonin for its being there
Old Jan 12, 2003 | 06:23 PM
Razorcat's Avatar
I believe lilnotts was pointing out the spelling error in your signature.
centrifugal decompressor? maybe automatic decompressor..not sure what you're talkin' bout
Old Jan 12, 2003 | 07:12 PM
thanks, i think its called the centrifugal decompressor, or centrifugal compressor, its something to do with centrifugal
Old Jan 12, 2003 | 07:19 PM
lilnotts's Avatar
ya, razorcat is right, i was just pointing out the spellin error, thus the wink at the end
and if i'm thinking about the same thing as u, the decompressor just lowers the compression so that it is easier on the starter wen the motor is turning slowly, but once it is turning fast enough the decompressor disengages, i hope this is wat u mean
Old Jan 12, 2003 | 07:46 PM
what would happen if it was taking off, just be harder for the motor ot start
Old Jan 12, 2003 | 07:50 PM
lilnotts's Avatar
well it would put more wearin on the starter, starter gears n battery, maybe more things too,someone else here could probably tell you alot more since i've never been inside a ds engine
how cold does it get there? y do you want to take it off so bad? did yours broken or somethin?
Old Jan 12, 2003 | 07:51 PM
Razorcat's Avatar
might not start at all, not easy to turn it over against the compression...
Old Jan 12, 2003 | 08:45 PM
it doesnt get to cold i guess, it gets maybe around the 20s or 30s any colder than that i wouldnt be on the bike, i dont what to remove it i was wondering what it did, we were thinking that it was maybe something to do with timing, and i didnt see how it work adjust the timing, but sence its not a timing thing its a compression thing, i still dont see how it works, its on the exhaust cam and when it picks up the rpms it will swing up and thats it, i dont see how its it on the compression either, i was wondering what it did and how it did it
