What tire presure
Old Jan 14, 2003 | 07:29 PM
KMDuner's Avatar
Default What tire presure
What presure should I air my haulers up to. 6, 8, what?
and don't say 0 Bigger[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 14, 2003 | 07:42 PM
biggerisbetter's Avatar
LOL!
It depends on the sand. If the sand is "heavy" you want to go up a bit on your tire pressure(6-8lbs)This will let the tires spin so the "heavy" sand won't BOG your motor, but if its loose and soft definatly want to go to about 4-5 pounds for better traction. If you go under 4lbs your tire may fold,causing the paddle to lay down under power.
But don't take my word for it.[img]i/expressions/face-icon-small-wink.gif[/img]
Biggerisbetter.
Old Jan 14, 2003 | 07:52 PM
KMDuner's Avatar
I would say that the the sand is loose and soft, so fine that you can't hold it between your fingers.
Old Jan 14, 2003 | 07:57 PM
Well, lets see if you have learned anything..
So what should your tire pressure be???
I'm waiting.....lol.
Biggerisbetter
Old Jan 14, 2003 | 08:05 PM
KenDS's Avatar
I run 3 psi cold in the rear and 5-6 psi in the fronts at Glamis regularly, seems to be the best for hook up on mine. The sand is very fine and the weather has been dry. At 6-8 it would be a ditch digger!
Old Jan 14, 2003 | 10:30 PM
Razorcat's Avatar
Ok what about tire pressure for normal dirt? hehe
the tires on the ds650 I test drove were really low on air I thought, they looked kinda flat. Very squishy, made it hard to turn. Dunno if the dealer put the reccomended amount in them or not
Old Jan 15, 2003 | 01:16 PM
KMDuner's Avatar
UUUUUMMMMMMMMM 6psi??????????
I never was good at math
Old Jan 15, 2003 | 04:06 PM
dragracer789's Avatar
i run 2.5 in the back and 10 in the front
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
