Sportsman 500 bottoming out
Old Jan 14, 2003 | 09:19 PM
AirFester's Avatar
Default Sportsman 500 bottoming out
A good friend of mine has a sportsman. This guy is pretty big and he bottoms the front suspension constantly over minor obstacles.
What are some options for him?
Thanks
Old Jan 14, 2003 | 09:59 PM
ftwflh's Avatar
He must be REAL big because I am 235 lbs and neither of my quads bottom out even on jumps.But I do have new shocks all the way around.
Old Jan 14, 2003 | 10:05 PM
500DUSE's Avatar
How old is the bike?
Miles?
My struts were shot after 2 years
and 1800miles.
Old Jan 14, 2003 | 11:18 PM
sprtsmnfan's Avatar
I had the same problem with my SP400...front-end was way too squishy. If the struts aren't toast, tell him to try the front spring/pre-load adjuster kit from Progressive Suspension. Kit includes stiffer front springs and the adjuster so you can fine tune it to your needs. Dennis Kirk carries 'em or you can take a look at them at progressivesuspension.com. It costs about a bill and a half but it is worth every penny. I love mine...they stiffened up the front perfectly and reduced some of rollover in the corners. Also made carrying loads on the front rack a lot less of a pain in the a$$.
A cheaper way out would be to put HD springs up front. They're $30 from Dennis kirk, but if they are too stiff for your liking you're SOL.(Not the way I would go, but the choice is yours)
Jmuddin284
Jan 19, 2026 07:16 AM
Jazperman
Aug 7, 2016 08:12 PM
merryman
Jan 19, 2016 04:29 AM
toonces
Aug 13, 2015 01:48 PM
austinwhitton
Aug 11, 2015 06:21 PM
