50 E-TON Viper?
Old Jan 15, 2003 | 04:33 PM
mxmike's Avatar
Default 50 E-TON Viper?
I bought my boy one for Christmas and its ran perfect so far.I think it hits the rev limiter to soon though.I heard it was adjustable or there is a wire you can cut to get rid of it,Does any one know how I can rise the rev limit?
Old Jan 16, 2003 | 10:36 AM
mascman's Avatar
Do they actually have a rev limiter on them? The first thing I did to my daughter's Skyhawk 50 is remove the brass limiter in the carb. Just pull the top of the carb off and it's right above the spring. Since you have it off, if you cut a couple coils off the spring it will make it a little easier on their thumb. Remember to adjust the throttle stop on the thumb for wide open throttle.
Another trick I heard was to put a K&N air filter on (part # RU-200 I believe) and drill the main jet with a .032" bit. It supposedly produces a noticeable amount of power. I am going to do it before spring. I am also told that putting the front sprocket from a 90 will make it faster. I am assuming that it is a larger sprocket, otherwise it would give it more torque. They probably have the same rear sprocket.
These mini quads use the same Yamaha scooter based motor. I am told that the 90cc top end will bolt onto the 50cc bottom end and there is a "big-bore" 105cc available.
Don't mean to get off your original topic...do you have any hop-up tips? I'm dieing to mod this little quad!
Old Jan 16, 2003 | 09:05 PM
mxmike's Avatar
I realy think it has a rev limiter.It starts to sputter when it hits it.
Anyone know anything about thes E-Ton 50cc's
Old Jan 23, 2003 | 10:20 AM
wcrook1007's Avatar
The rev limiter is in front of the steering shaft behind the front plastic a brown box you have to cut the green wire coming out of the box on the back on the 90 Viper that is what I have. Pull back the rubber backing that holds the box in place my dealer showed me this. It really helps. I hope this helps you.
Wayne
Old Jan 23, 2003 | 12:43 PM
TRexTommy51's Avatar
WCrook is right. Cut the green wire and you can rev to the moon. Well you need some more stuff for that but it will help.
Old Jan 23, 2003 | 07:13 PM
mxmike's Avatar
Thanks guys.That works for the 50 and 90?
Old Jan 23, 2003 | 07:18 PM
mxmike's Avatar
wcrook 1007,I noticed you been a forum member since 99 and have only posted 14 times.I want to thank you again for taking the time and posting this info.
Old Jan 23, 2003 | 08:38 PM
Mike, Ya'll do any mini racing down there with the Hinton folks?
Old Jan 23, 2003 | 08:53 PM
mxmike's Avatar
You talking about Mark?
I been racing with his son for the last year.They are very nice people.We plan on getting the kids racing in march.After the winter searies.
Old Jan 24, 2003 | 07:05 AM
Yeah, I talked to him a few times on the phone. He seems super nice. I am hoping Koty and I can get down there sometime and ride with ya'll.
