Lighter DS for 04
Old Jan 21, 2003 | 05:05 PM
BillDS650's Avatar
Default Lighter DS for 04
The March issue of DW has a sneak peak at the 04 DS650 Bombardier is working on. They are trying to get it down too 430 lbs dry. The quad DW tested was at 460 down form 490. It had a new 1/2 inch shorter Aluminum swingarm. The new lighter head light that will save 3 too 6 pounds
Old Jan 21, 2003 | 05:36 PM
Gottahavaraptor's Avatar
That confirms what my dealer told me a couple of weeks ago. He also said that there is a DS400-450 coming too.
Old Jan 21, 2003 | 05:44 PM
BillDS650's Avatar
From what I saw it looks like the new parts will bolt on too the older DS's.
Old Jan 21, 2003 | 07:21 PM
duneDS650's Avatar
Does the headlight look more durable and cheaper to replace when the little tabs break off?
Old Jan 21, 2003 | 07:55 PM
BillDS650's Avatar
Cant see much of the unit but it is a daul light with new mounting bracket
Old Jan 21, 2003 | 08:03 PM
Squidward's Avatar
As I mentioned in a post last month, there will be two new sport models from Bombardier, the Baja X, which will be based on the current Baja, but considerably lighter, and an all new aluminum framed 400cc sport quad. Expect to see the Baja X available in August-Sept, and the 400 late in the year.
Old Jan 21, 2003 | 08:25 PM
Overkill's Avatar
If they're making a DS400 or 450, I will probably be getting one for my wife. I can't wait to see it. Are there any pictures available??
Old Jan 21, 2003 | 08:51 PM
SANDMAN430's Avatar
i've been looking at my quad and seems like all the frame around the air box area could be aluminum. but would that put to much weight on the front? anyways looks like all of that area bolts on. it is nice to hear that it looks like some of the new parts will bolt to the older models.
Old Jan 22, 2003 | 12:13 AM
AlaskaYFM's Avatar
I'm sure that Rotax has a nice 450cc DOHC four-stroker that will give the Z and EX a run for it's money, provided that they keep the weight down.
Old Jan 22, 2003 | 12:19 AM
lilnotts's Avatar
i'd say modify a Summit 800 H.O motor so it could be used in a quad, now that would be SWEET![img]i/expressions/face-icon-small-smile.gif[/img]
