Degreeing Stage 2 web cam??
Old Jan 25, 2003 | 04:33 PM
XxDumontRaptorxX's Avatar
Default Degreeing Stage 2 web cam??
Is it really that important to degree a stage 2 web cam? If so how do i do it?
Old Jan 25, 2003 | 05:06 PM
anyone? i need help!!
Old Jan 25, 2003 | 07:01 PM
pvtCowboy's Avatar
If you trust that they made the cam to perfect specs then no you don't *have* to do it. It just verifies that the valves open at exactly the correct time. If you have never done it I would suggest that you contact someone who has to check it for you. It requires a degree wheel and a dial indicator to do.
Old Jan 25, 2003 | 07:22 PM
likestogofast's Avatar
We have the degree wheel and the dial on the engine right now, just surfing to see if we can talk to someone who has done it. I assume the only way to change the timing is to actually move the gear flange on the cam? We are getting about 19 deg btdc on the intake, so we are 4 degrees early on the timing. I am worried that that might make a big difference, but not really sure. I guess we could always throw a bit more advance on the ignition timing, but that might make the valves very unhappy with the high lift of this stage 2 cam. Any thoughts?
Old Jan 25, 2003 | 07:31 PM
oops, i shoulda said late. cam card says 24 btdc, and its not at 0.050" lift until 19 deg btdc. exhaust is about the same, but not as bad, only 3 degrees late.
MikeyBoyesq
Sep 22, 2015 10:02 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Elkaholic
Sep 6, 2015 02:44 PM
Sep 2, 2015 11:15 PM
