Long Travel A-Arms
Old Jan 25, 2003 | 06:15 PM
Cublime's Avatar
Default Long Travel A-Arms
What front A-arms is everyone running and where did u get them. The front suspension on the cannibal is going to have to go and I'm having no luck comming up with any ideas except LSRacing..
Thank you in advance
Old Jan 25, 2003 | 06:45 PM
mxmike's Avatar
Im running the stock moto front end.So far its been SWEET.It was night and day diference from my stock speed front end.I got about 4 months on it.
Old Jan 25, 2003 | 09:21 PM
cannondale27's Avatar
I have the moto front too I love it.Lonestar uses some sleeves to fit the ball joints to the spindles I really think that is a bad idea I have seen them come loose and get all bagged out only thing holding the nut on was the cotterpin and this guy had checked them before the race.
Old Jan 25, 2003 | 09:26 PM
Sandgod's Avatar
I have a Moto front end and my brother a Houser front end. Both are +3's and same wheels and his is at least two inches wider.. You need a stem for the Houser front end.. Boooooo!!
Old Jan 25, 2003 | 09:30 PM
Cublime's Avatar
So it sounds like Cannondale did a hell of job designing their own arms.. So my question is.... Do you buy these from a dealer or does somebody sell these on their we3bsite?? Also I figure I need newshocks for these so how long do they need to be???
Old Jan 25, 2003 | 10:16 PM
Cannondale offers it as a kit Arms,Brakelines and Shocks or seperately your dealer can order it for you.I really like the moto Ohlins in the kit but the ride height is higher than PEP,Elka etc.The shocks are the 19 in. long travel type so you will need new shocks.Also if you have a early 02 with the narrow a-arm mounts the moto bushings will dig into frame I have a fix for that.
Old Jan 26, 2003 | 01:31 AM
smitty911's Avatar
I'm looking at getting some Eyeball Engineering long travel with stem. about 1,100 and long travel TCS Shocks. Have to wait for some more money to start rolling in though.
Smitty
Old Jan 26, 2003 | 04:22 PM
buddah's Avatar
I'm running Houser +3'' long travel arms with the new TCS bodied shocks. I have no complaints what so ever. You will need a different stem with The Houser arms or the tie rods will hit the frame. The plate is mounted 10mm. lower. I installed an Arens stem but Houser offers them as well. I had Works shocks on my stock arms and they performed really well. The set up I have now is definitely worth the extra cost. The shocks soak up everything and the width of my front end is 51.5 inches and you can rail around the corners. I'm really pleased with this set up and recommend both manufacturers. I did a lot of research with racers back East before choosing Housers. They have a great reputataion and the craftsmanship is first rate.
Old Jan 26, 2003 | 07:33 PM
350mx's Avatar
Gibson,merrell extreme,and houser are all great and look like you got something for your money. You can get any one for a little over 2000 with custom axis shocks.
Old Jan 27, 2003 | 11:22 AM
Cublime's Avatar
Ok so there is alot of good setups out there. Who other then houser cause I found them on there site sells theese setups?? I have tried to find Walsh, Laeger, Gibson setups all over with no luck...
