87 honda 250x
Old Jan 26, 2003 | 11:55 PM
dei0801's Avatar
Default 87 honda 250x
I bought a 250x from my cousin last year really cheap. The problem was it had spun the main bearing on the crankshaft. Well i took it apart and gears in the bottom end went everywhere. I got a service manual and all new parts and put it back together just like the book said and i cant get it to shift gears. Before it messed up i had rode it once and first gear was not working, it was like it was skipping a tooth or something but none of the gears were messed up. Does anyone know why i cant get it to shift or what might fix my problem other than a new motor?
Old Jan 27, 2003 | 12:22 AM
Need4Speed's Avatar
Make sure you have all the gears and washers alligned perfectly on the tanny shafts. Make sure that you have all the pawls and caps and springs together on the left side of the engine on the shift drum installed correctly. You could have any number of different things wrong that's giving you the problems you're having. When everything has to go together perfectly or else it can spell disaster. If I were you I'd crack it back open and start from scratch and make sure you have everything installed right.
Old Jan 27, 2003 | 09:52 PM
dei0801's Avatar
thanks speed for the input. i think my problem is coming in the shift drum section because ive put everything else in just like the book said so ill go back and try it again i guess. thanks again
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
