Does anybody have the new Dyna Ignition for the raptor?
Alljuice- I had one on the 2001 for 3 weeks. It was a lot of money but that was where i was at. It helped me out on the top-end on the drag strip. It will help more if you run Alky. I ordered me a new one for the 2003 today. I would say it was good for 1.5 HP.
alljuice -
I just got a Dyna ignition box for my raptor this past week. I also added a Pingry airbox and upped the mains at the same time. IT RIPS! I can't say which change was responsible for the extra power, but there is a huge increase. I would say it is as big of a difference as going from the stock pipe to the Yosh pipe/remove lid combo.
You can feel a difference switching between the 4 curves also. One curve is stock. The other 3 actually make my quad much louder and change the acceleration characteristics. Before, when I drop the clutch in 2nd gear on a dirt road it would bog down. Now it roosts! I am going to a dyno in the next couple of weeks to get my jetting adjusted perfectly. I will try to post the results. Here are my current settings -
175/180 mikuni mains
25 pilots
stock needles on 3rd clip (middle)
fuel screw ~ 2.5 turns out (this changes slightly with the different advance curves)
Pro-Flow foam filter
PPD aluminum airbox/battery box
Yosh Full Stainless pipe
Good Luck, www.pro-flo.com sells it for $370, most others sell it for $410
RR1
25 pilots
RR1
Don't worry alljuice. This isn't a banshee story.
I told you all it is one kick a$$ ignition. Wait until you start making your own curves. This is where it shines. I also said pro-flo was the cheapest.
Does anybody thank the guy with the banshee?[img]i/expressions/face-icon-small-disgusted.gif[/img] No, you just tell him not to post his thoughts[img]i/expressions/face-icon-small-smile.gif[/img]. If I put raptor plastic on my banshee could I be in your "raptor clique"[img]i/expressions/face-icon-small-tongue.gif[/img].
Shane, what is your compression, fuel, and estimated rpm range?
"I just got a Dyna ignition box for my raptor this past week. I also added a Pingry airbox and upped the mains at the same time. IT RIPS! I can't say which change was responsible for the extra power, but there is a huge increase. I would say it is as big of a difference as going from the stock pipe to the Yosh pipe/remove lid combo. "
Wow that is quite a difference! were you running a lid on the previous set up????
Would be nice to know which on made the biggest change in HP??
Shane, your engine will differ from a built raptor. What compression, fuel, and estimated RPM range will you engine be using? Also, what is the weight of you and your bike? With this info we can pick a good starting curve for you.
14mins, I noticed the dyna program will let you go up to 75 degrees advance! Nothing will lighten a piston like a hole in the center[img]i/expressions/face-icon-small-smile.gif[/img]. They limit a banshee to 27 degrees.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
