cylinder question???
Old Jan 28, 2003 | 07:24 PM
whitebread's Avatar
Default cylinder question???
will i need to have anything done to my cylinder before i put the 11:1 standard bore piston in?[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 30, 2003 | 05:36 PM
SpDdEmOn's Avatar
no
Old Jan 30, 2003 | 06:13 PM
RacinJason's Avatar
you should measure to make sure it isn't out of round and need a bore job-the cylindar will at least need a hone job to allow the new rings to seat properly....only a few bucks at a machine shop.
BRAAAAAAP
Old Jan 30, 2003 | 06:53 PM
DaBeechMan's Avatar
yup just make sure you have a straight bore slick
Old Jan 30, 2003 | 08:58 PM
whitebread's Avatar
i've got a ball hone to hone it with to make sure the rings fit properly.
Old Jan 30, 2003 | 09:12 PM
DaBeechMan's Avatar
what angle to do hone your cylinder at?
Old Jan 30, 2003 | 09:19 PM
whitebread's Avatar
somebody said to do it at 45 degrees,does this sound right?
Old Jan 30, 2003 | 09:21 PM
DaBeechMan's Avatar
Yes that is correct. Just making sure the fellow racers are ball honing correctly.
Old Jan 30, 2003 | 09:23 PM
whitebread's Avatar
explain to me how exactly to do this??
Old Jan 30, 2003 | 09:28 PM
DaBeechMan's Avatar
the way we do it (with a ball hone) is to put the cyl in a vice at a 45 degree angle with a towel wrapped around it to keep from scratching the cyl. go in through the top because often times the ***** will get hung up in the transfers. Put oil in the cylinder and on the hone like a spray lubricate ect ect and hit it as close to a 45 as possible. Make sure your cross hatches are good and basically be carefull taking too much material out.
