Raptor Jetting help
Old Jan 29, 2003 | 02:23 PM
HeyBeerMan's Avatar
Default Raptor Jetting help
I have a 02 Raptor. With Pro flow filter kit no lid & carved up like swiss cheese, and a full Yoshi set up. After I got it all on. I set out to jet it. I did just like the Yoshi instructions said. But it would bog really bad on low end. Nothing I changed would help. Except if I covered a few of the holes on my air box. Then I would have to lower the main jets.
It seemed like it did not have enough vacume to activate the diaphrams. Does that make sense? Would weaker springs help?
Any ideas???
TIA!
Old Jan 31, 2003 | 06:44 PM
HeyBeerMan's Avatar
BTT
Anyone?
Old Jan 31, 2003 | 08:06 PM
sixsixT's Avatar
GYTR jet kit
160/165 mains
needle 3rd groove
2 1/4 left 2 1/2 right mix. screws
25 pilot
no lid
check float level
choke
boots to carbs.
make sure your slides are moving freely and check and make sure the diaphrams did'nt get damaged and are sitting in the carb. correctly.
would'nt hurt to check your valves while your in the area if it has'nt been done lately.
Is your lid or box carved up?
Old Jan 31, 2003 | 08:09 PM
03Raptor's Avatar
Does it back fire a lot when you let of the gas after a full trottle burst?
What type of jeyt kit does the Yoshi send?
Shane
Old Jan 31, 2003 | 11:36 PM
jraptor's Avatar
mine backfires after full throttle burst
Old Feb 1, 2003 | 02:29 AM
GregV's Avatar
If you got the same instructions with your Yosh pipe that I got with mine, it is WRONG!!
Mine said to turn the screws "OUT ONE TURN". Mine wouldn't even start!!
Where are you on your air/fuel screws??
Old Feb 1, 2003 | 03:16 AM
jraptor's Avatar
2 1/2 on right & 2 1/4 on left
Old Feb 1, 2003 | 03:23 AM
GregV's Avatar
What pilots are you running?
Old Feb 1, 2003 | 03:26 AM
jraptor's Avatar
25 pilots
Old Feb 4, 2003 | 01:00 AM
kyraptor23's Avatar
I just took the lid off of mine yesterday and rejetted to 148/150 dj whereas before i was at 146/148 with screws 3 turns out. I didnt notice any backfiring prior to taking the lid off but i removed the spark arrestor also from my yoshi and it backfires or more of a sputtering when i let off after full throttle. Is this normal??
bmxatv10
Oct 14, 2022 06:23 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
