Weight Reduction
One of the mags had an article about this within the last year I believe. I wish I had more info than that but they claimed to get 50 pounds off the DS. They did drill holes in some part of the frame but it was a while ago and I cant remember. I know they were very strategic about where they drilled the holes.
Have you tried finding a welding shop that would build you a frame from Chromoly steel? I remeber talking with a guy about a year ago that would build any frame made from chromoly for about $1,500. I thought this was reasonable since frames from LSR, Leasgers, Gibson, Aerons are a lot more than that.
I would be very cautious with drilling holes in the frame and sub frame.
Areas I think you can save weight on the DS650
1. TVI aluminum swing arm the +4 is 17 lbs lighter than the stock one.
2. Remove front fenders and replace a-arms save about 12 pounds
3. Remove the fan -2 lbs
4. Titanium rear axle saves up to 17lbs
5. DuraBlue aluminum sprocket hub -50% over stock.
6. Aluminum front bumper and rear grab bar
7. Replace all bolts with titanium ones save a pound but spend about $500.00
8. Replace rear brake light wit LED light bar -1 lbs and look cool
Parts that could be made
Billet aluminum foot brake and shifter.
Aluminum tie rods.
Rumor has it that the 04 DS might have aluminum upper A-arms
Remove stock head light and oil tank and replace with new aluminum oil tank in same place.
Make new front spindle and hubs.
Make new sub-frame out of aluminum
Aluminum tie rods.
and..
-shave rear fenders
-Put small RCI fuel cell on it....maybe like a 1 liter for one drag race-use hauler paddles
-struts instead of shocks
-an aluminum bearing carrier
-remove front brakes
-remove dash
-remove air box/ snorkels
-run .125 wheels for drag racing
-run a smaller chain
thats all i can think of....
dont drill holes in your frame scooby.....
-shave rear fenders
-remove dash
wow with all these calculations what you guy's are saying is my bike could be made 55-60 lbs lighter than stock???[img]i/expressions/face-icon-small-shocked.gif[/img] Then what would happen if i removed the sub frame cut off all the unwanted trash. Replaced the batt. box with a alum moved all the elec gadgets farther forward. Ran triple buffs all around used a glycol lucos mixture instead of water removed all sprocket protectors. Cut out all excess wiring from wiring harness replaced the steering stem with a lighter unit. you think maybe 68.9 pounds[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-wink.gif[/img]
OUCH that weight thing hurt hoover[img]i/expressions/face-icon-small-wink.gif[/img]
And buttfungus i like your thinking[img]i/expressions/face-icon-small-happy.gif[/img]
