85 250r twist throttle
Old Feb 3, 2003 | 02:50 PM
sweetcorn's Avatar
Default 85 250r twist throttle
I have been trying to find a new twist throttle and cable for an 85 atc 250r with a 39mm carb, I found a twist throttle that says it is for 28 to 40mm carbs, but the only twist cable I could find were for an 86 atc 250r. does anyone know if the 85 and 86 cables are the same length? any info will help, thanks
Old Feb 3, 2003 | 05:39 PM
trx250Rob's Avatar
They should be the same, very little change between 85-86. Also the 86-89 trx250r used the same carb and engine, so those will work too.
Old Feb 16, 2003 | 08:37 PM
KASEY's Avatar
the twisters and cables are the on my 85 and 86 250r's 85-86
Old Feb 21, 2003 | 10:28 PM
250sx's Avatar
I have several twist throttles which I'll trade for thumb throttles!
Old Feb 22, 2003 | 12:45 PM
trx250Rob's Avatar
I would too, I feel twist throttles on powerful atvs are pretty dangerous.
Old Feb 22, 2003 | 08:51 PM
sweetcorn's Avatar
thanks for the input, I ended up getting an 86, cable and a 28-40mm twist, the cable housing was to long so IT took some modifing to get it to work. I will agree a twist has it's disadvantages when steering, But they are alot more fun then a thumb, especially on a high reving 2-stroke.
Old Feb 22, 2003 | 10:32 PM
trx250Rob's Avatar
I believe it is more a matter of preferance than anything else but had too many close calls to continue using a twist.
One I could remeber was landing a little to one side. My butt fell through the right side and that was enough to have my wrist twist the throttle wide open off a 20 foot ledge. I have many more stories like this but I will not bore you.
Alex Rodak
Sep 13, 2015 12:30 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
89Lt250r
Sep 7, 2015 07:53 PM
