85 250r twist throttle
I have been trying to find a new twist throttle and cable for an 85 atc 250r with a 39mm carb, I found a twist throttle that says it is for 28 to 40mm carbs, but the only twist cable I could find were for an 86 atc 250r. does anyone know if the 85 and 86 cables are the same length? any info will help, thanks
thanks for the input, I ended up getting an 86, cable and a 28-40mm twist, the cable housing was to long so IT took some modifing to get it to work. I will agree a twist has it's disadvantages when steering, But they are alot more fun then a thumb, especially on a high reving 2-stroke.
I believe it is more a matter of preferance than anything else but had too many close calls to continue using a twist.
One I could remeber was landing a little to one side. My butt fell through the right side and that was enough to have my wrist twist the throttle wide open off a 20 foot ledge. I have many more stories like this but I will not bore you.
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
