Removing plastic on Z400
What is the best way to remove the front plastic and gas tank without messing up the plastic fastners? Do I even need to remove all that to rejet? I've never done any jetting so I'm just assuming I need to take all that stuff off to get at the carb. If I do need to take it all off what is the best way to get the fastners out without damaging them? HELP!!!!!!!!!!!!
Thanks for the info on the plastic clips!! I would of just pried the little bastards out!! I did have to remove the front plastic and the tank to get the carb out though. Replaced the needle and put a 150 main in, everything seems to be good, started right up and idles fine. Can't wait to put the pipe on and take it for some testing!!!
Jul 15, 2015 02:07 AM
