Which axle for 250R?
Old Apr 13, 2000 | 10:40 AM
RichinMI's Avatar
I just noticed that i need a new axle on my 86 250r. Should i spend 300 on a eliminator? What about dura blue's HD axle...how does it compare to the honda stock axle. I have little need to make it wider than stock, but this may be something that i may want in the future. Im just not sure what to buy..i can get a stock honda axle for 200, a eliminator for 300 or a HD for 249. What do you all think?
Old Apr 13, 2000 | 05:26 PM
THEXOTIC1's Avatar
I had the same problem stock axles are juust not built strong enough. I have an 87 quadzilla with a eliminator axle +2 inches on the bike. I have bent this one already and got another one. after that i havent had a problem with this axle. I also have an 87 250x which the splines were worn down and the hubs rocked. So i put a used dominator axle on the 250x that had +1 +2 settings with sleeves that slide on the axle so i took the sleeves off of the axle and put the hub all the way on and put the sleeves on the outside of the axle. So now i have a stock size axle that can be moved +1 or +2 in the future.
Old Apr 13, 2000 | 07:18 PM
StockRacer's Avatar
I am not real sure about how much a Lonestar axle costs (expensive), but they are very strong, and have a lifetime warranty. They also have sleeves to slide over the splines so that you can adjust the width of the axle. I believe it goes from minus 1 to plus 2 on each side. In my opinion, I would spend the extra to get an axle with a lifetime warranty so that I never had to buy one again.
Old Apr 13, 2000 | 11:38 PM
trx430ex's Avatar
Make sure the warrenty is not pro rated. Read the fine print.
The dura blue remained straight.spacers are opp for width.
Old Apr 14, 2000 | 12:00 PM
Raychalp's Avatar
You should buy my brand new Lonestar axle for $325, which is a substantial savings over new. It has a lifetime warranty and I have never broken one before.
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
1000gade
Sep 9, 2015 04:41 PM
