CHANGING TIRES ON 400EX?
Old Apr 13, 2000 | 12:34 PM
WOODRIDER400's Avatar
If I change the tire size on my 400 to run bigger tires in back and front what size sprockets am I going to have to get to keep the gearing the same.
22" rear holeshot xct's
holeshots on front bigger than stock.
this is for ground clearance on rocks and stuff.
Old Apr 13, 2000 | 03:48 PM
philzie's Avatar
I am running 22" all tracks on my 400EX with stock gearing. It works great, and I do A LOT of hill climbing. I use second instead of third, and I can out climb any other 400EX around here, so far...
Old Apr 13, 2000 | 05:10 PM
Kirk_D4's Avatar
I just yesterday put 22 inch tires on mine. I think it is just right.
Old Apr 13, 2000 | 09:53 PM
hot_shoe_cv's Avatar
I think if you dropped one tooth on your c/s sprocket, you'd be in the ball park. I did it the other way around on my Warrior, going from 22" rears to 20". I tried a 14 instead of a 13 & it was about the same as stock. I now run a 15 for greater top end.
I don't know that I'd alter the front tire size, tho, since most clearance problems are concerned with the rotor or rear sprocket.
Old Apr 14, 2000 | 05:03 AM
norm440EX's Avatar
The 400EX stock is geared kinda low anyway unless your riding a lot of realy tight slow trails or sand dunes. The extra tire diameter will help your top speed and ground clearance and you probably won't feel the difference in acceleration. If you do want to change, I would go two teeth bigger in the rear, one tooth on the countershaft makes a big difference in gearing, two teeth bigger in the rear might not be so dramatic.
Old Apr 19, 2000 | 01:14 AM
Rdogg's Avatar
I also have the 22" XCTs on back and 23" holeshots on front .
I put a 14 tooth front sprocket on mine and it helped out alot.
It seeed like my 400 bogged a little bit in the tight trails in harescrambles with the heavy XCTs on the bike.
Rdogg '99 400EX
#46 MHSCA
Reactant
Mar 30, 2022 02:08 AM
metal249
Jul 28, 2015 09:35 AM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
