JETTING QUESTIONS FOR A RAPTOR
Old Feb 4, 2003 | 08:44 PM
rc3's Avatar
rc3
Default JETTING QUESTIONS FOR A RAPTOR
Well I just bought a Raptor I am putting a complete yoshimura exhaust system on it, a Dyno Jet Kit, I have a K&N Filter with the lid all cut open. I ride the Oregon Sand Dunes. Any help would be great, should I go up on my Pilot's, what position on the needle's and what size main jets.
THANKS
Old Feb 4, 2003 | 08:54 PM
holeshot77's Avatar
I have a question also my raptor sputters when just cruising at low speeds about 1/4 throttle but when i open her up she runs like a champ, any suggestions [img]i/expressions/face-icon-small-mad.gif[/img]
Old Feb 4, 2003 | 09:00 PM
rc3's Avatar
rc3
did you change your pilots, if not you might want to go up a size, if you did change them, then maybee go back down one size!
Old Feb 5, 2003 | 01:44 AM
kyraptor23's Avatar
rc3, look at my signature, mine runs strong with no hesitation. Im about 1000ft.
Old Feb 5, 2003 | 01:45 AM
kyraptor23's Avatar
and i have stock pilots with 3 turns out on the mixture screws
Old Feb 5, 2003 | 01:50 AM
THEMOOSE's Avatar
If you look at the Dynojet instructions it says the kit is designed to use the stock pilots, so I did.
However, I too have the burbling problem if I'm putting around at less than 1/4 throttle for a while.
I'm going to try turning the Air corrections a bit too see if it clears up.
Old Feb 5, 2003 | 07:59 AM
660RVelociraptor's Avatar
I also have the same settings as you do.
'01 raptor
Full comp CRD
K&N no snorkel 148/150 DJ
stock pilots
I ride at sea level.
I am going to 150/155 main. What do you think and what should i change ? Should i change the pilots ? Should i take the lid off ?
Thanks
Old Feb 5, 2003 | 03:31 PM
zanman's Avatar
can anyone tell me what size of mikuni jets to use .03 raptor full fmf titanium w/powerbomb header,airbox mods,ngk platinum. thanks
Old Feb 5, 2003 | 07:08 PM
rc3's Avatar
rc3
What about the needle position, I bought the Dyno Jet kit, it says the fourth clip down, but it does not talk about running with your lid off. Thanks for all of your help
Old Feb 5, 2003 | 08:30 PM
kyraptor23's Avatar
needles in third from top. Good luck
