grizzly question
Old Feb 6, 2003 | 12:59 AM
grizzkiller's Avatar
Default grizzly question
i was wondering what a flashing reverse light in the range selecter on a grizz 660 meant, if anything. figured i should ask other grizz owners.
Old Feb 6, 2003 | 12:05 PM
icecleric's Avatar
Is it flashing all the time or just after high speed runs? Afyter high speed runs it is telling you you hit the rev limiter.
Old Feb 6, 2003 | 12:34 PM
Grizzhaus660's Avatar
My buddies Grizzly did the same thing when his dummy light(temp warning) went out. The reverse lite flashed to let him know. I have also heard it will flash when idling to high. Hope that helps.
Old Feb 6, 2003 | 01:58 PM
actually it did it when idling in my garage after a long ride and on a cold day after i started it and it just warmed up.
Old Feb 7, 2003 | 11:42 PM
ProEMTPFF's Avatar
Ok, the reverse light flashing does several things. #1 lets you know your over reving the enging, #2 its a "code" count how many times it flashes, call your dealer and ask them what code its for. Mine did the same thing while I was warming it up, I'd let it idle for a few mins. then start reving it slightly. Well I found that if you hold the throttle down even at a "fast" idle for a few mins the reverse light will start flashing. I called my dealer and went down and showed him. He started counting he got to 26+ flashes and said it was'nt a code. Anyway, count the flashes, call the service shop and ask them " what do this many reverse light flashes meen?" The amount of flashes indicate a "problem" somewhere unless it goes over a certain amount, I believe it was over 26.
cornermike
Sep 10, 2015 08:30 AM
Rooky
Sep 9, 2015 03:16 AM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
