Snorkel kit for Beartracker?
Old Apr 13, 2000 | 07:48 PM
beartracker10's Avatar
Hey, i know it sounds a little stupid,for a 2wd 250, but is there any way i can make some sort of snorkel kit for my beartracker? What do i need to connect where? I normally ride the rivers here in iowa from sand bar to sand bar, and i think that something like this would be ideal for the conditions. Any help would be greatly appreciated, thanks!
2000 Beartracker, red, superwinch T1500
Old Apr 14, 2000 | 10:53 PM
95TimberWolf's Avatar
hmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm mmmmmm. ill try to help u. ill think aboutit over the weekend and let u know. ok?
Old Apr 14, 2000 | 11:53 PM
Hey, thanks man, it would be really appreciated
2000 Beartracker, red, Superwinch T1500
Old Apr 17, 2000 | 05:52 PM
ya i thought about it. u can use some plastic tubing probally and some big rubber hose(ie. like that of a radiater hose) some clamps and glue. i hope this helps u out some. if u need more help let me know because i probally could plan the whole system out for u.
Old Apr 21, 2000 | 05:38 PM
BiGMiKe's Avatar
My buddy and i mad one out of pvc and had to rejet the carb, it works great
Old Apr 22, 2000 | 11:11 AM
when u added ur new snorkle to it, did u feel any power increase since u were increasing the flow of air and u had to rejet? im kinda thinking about making one but my dad probally wont agree with me. beartracker10, what tires are u running on the rear? stock? on my t-wold 2Wd im running Carlisle Tire Co.'s Stryker. there pretty good if u run them at a low RPM they will plug up some but if u run them at a higher RPM they will stay clean and they also have lots of traction i found out. i would like to have a better tire on the rear but since we use our 4 wheeler for farming i cant. I hope u had good luck making ur snorkle. d
Old Apr 22, 2000 | 09:42 PM
BiGMiKe's Avatar
we have 25'' vamps and hyes the power did increase we can still pop wheelies
Old Apr 23, 2000 | 11:42 AM
Im running the stock 22-10-10 Carlise Trail wolfs. They work ok, but i think im going to swap them for a set of Realtors, are they any good? I think if i turned them around and ran them backwards they would work really good on the sand bars. For the snorkel, what do i have to conect the hose to? Will i have to cut the air box or what? I have no clue. Also, will i need a Dynojet jet kit if i put a snorkel on it? Or would i have to just change the needle position? I know very little about carbs, but ihave a buddy that knows about them. And Does Supertrap or any other company make an aftermarket exhast for the beartracker?
Thanks for all of the help so far
Jeff
Old Apr 23, 2000 | 10:48 PM
u would hook it into the air intake snorkle that was stock, that is what i wopuld do. im thinking about adding one just for more air flow. which means more powa. does this help u out any?
Old Apr 24, 2000 | 06:04 PM
yes this is helping, but what do i need to do with the carb because of the extra air flow?
thanx
