Snorkel kit for Beartracker?
Hey, i know it sounds a little stupid,for a 2wd 250, but is there any way i can make some sort of snorkel kit for my beartracker? What do i need to connect where? I normally ride the rivers here in iowa from sand bar to sand bar, and i think that something like this would be ideal for the conditions. Any help would be greatly appreciated, thanks!
2000 Beartracker, red, superwinch T1500
ya i thought about it. u can use some plastic tubing probally and some big rubber hose(ie. like that of a radiater hose) some clamps and glue. i hope this helps u out some. if u need more help let me know because i probally could plan the whole system out for u.
when u added ur new snorkle to it, did u feel any power increase since u were increasing the flow of air and u had to rejet? im kinda thinking about making one but my dad probally wont agree with me. beartracker10, what tires are u running on the rear? stock? on my t-wold 2Wd im running Carlisle Tire Co.'s Stryker. there pretty good if u run them at a low RPM they will plug up some but if u run them at a higher RPM they will stay clean and they also have lots of traction i found out. i would like to have a better tire on the rear but since we use our 4 wheeler for farming i cant. I hope u had good luck making ur snorkle. d
Im running the stock 22-10-10 Carlise Trail wolfs. They work ok, but i think im going to swap them for a set of Realtors, are they any good? I think if i turned them around and ran them backwards they would work really good on the sand bars. For the snorkel, what do i have to conect the hose to? Will i have to cut the air box or what? I have no clue. Also, will i need a Dynojet jet kit if i put a snorkel on it? Or would i have to just change the needle position? I know very little about carbs, but ihave a buddy that knows about them. And Does Supertrap or any other company make an aftermarket exhast for the beartracker?
Thanks for all of the help so far
Jeff
2000 Beartracker, red, Superwinch T1500
Jeff
