Just picked up my 00' 400ex Yesterday
Old Apr 14, 2000 | 01:56 AM
TDBRPH's Avatar
Sorry I just had to share, I picked up my new quad yesterday and have been fortunate to already have 2 good rides to begin the break in process. Any riders from west-central missouri out there ? I have been riding at Finger Lakes State Park North of Columbia, MO. The 400ex is a great bike and very fun to ride no second thoughts here. GO HONDA !!
Old Apr 14, 2000 | 03:13 AM
azrob's Avatar
Make sure that you tighten the throttle cable to remove the slack. Otherwise you won't be getting full power when giving the 400EX full throttle.
Old Apr 14, 2000 | 03:28 PM
Motorhead's Avatar
Wow, me too!! I just got to ride it around in the field by my house for 3-4 hours, only used about half a tank of gas! Of course, I was keeping it around 1/4 throttle most of the time, breakin in the engine. I absolutely love the machine, no regrets here either!
azrob: I'd heard about the throttle cable problem.. do you tighten it up on the handlebars, or down on the carb somewhere? And how do you know when you have it tightened enough? Thanks
Old Apr 14, 2000 | 05:01 PM
Air's Avatar
Air
Let the mods begin!!!!!!!!!!!
99 426ex, web cam, FCR carb, DMC exhaust, XCT,s ,
DG nerfs, K&N, ported And polished.
Quick and fast
Old Apr 14, 2000 | 05:08 PM
b(250rman)'s Avatar
I am going to race at hawk point missouri. I live azbout 50 miles south of st luios. I ride a 250r. well remeber ride red ride smart and ride hard!!!!!!!!!!!!!!!
Old Apr 14, 2000 | 07:47 PM
Tomg's Avatar
How long does Honda recommend the 400ex is run-in for ?
Old Apr 14, 2000 | 10:20 PM
EXtreme-'s Avatar
Start by removing the black air intake boot on the back side of the carb. Look into the large hole and the choke will be visible. Beyond the choke, work the thumb throttle and you will see the "slide" moving up and down. At full throttle, the slide should be seated all the way to the top (dissapearing from sight). Take your finger and check for further movement if there is room and
adjust the cable at the thumb throttle till the slide remains at the top position at full throttle. You can bet the ranch that there will be room to raise it on a 2000 model!...probably at least 3\8ths of an inch. Re-install the boot and let her rip.
The difference is unbelievable! I had to practically sit on the gas tank to keep the front end down through every gear!
Old Apr 14, 2000 | 10:42 PM
GB400's Avatar
Air,
How is the full power band with the DMC ? Would you recomend it ? Do you have the full system ?
Where is a good place to buy one and how much ?
Thanks,
Old Apr 15, 2000 | 03:54 AM
Motorhead's Avatar
Thanks for the how-to, I'll check it out tomorrow. The thing already practically yanks me off the seat when I give the throttle a little jab, I'll be hangin on for dear life after adjusting it.
Old Apr 15, 2000 | 01:45 PM
supertraprecon's Avatar
thanks alot i am gonna check that on my quad i am sure not just 400exs are like that probaly almost all new atvs tell you how it go's
